AIP-SSM-10 Connectivity
Nov 3rd, 2007
We have bought a ASA5510 with AIP SSM 10 recently. AIP has one interface. And ASA has 4 interface. I need to know the connectivity system. Could someone please tell me what will be the connectivity. What to connect in AIP interface. Should I connect this port with any of the 4 ports in ASA and then send all traffic from ASA to AIP.
Please, I am new with this security product. Waiting for your reply.
Overall Rating: 3 (1 ratings)
The interface on the AIP SSM is for management. This can be plugged into any network that you prefer. Once it is plugged in to the preferred VLAN, change the IP info to reflect the new network. I WOULD NOT recommend connecting it directly to an ASA interface!! This can cause problems... Since the AIP monitors the backplane of the firewall, you won't need any other connections than the management connection. Also, you will need to configure your ASA to send the interesting traffic to the AIP for inspections.
Please rate useful posts.
