11-04-2007 12:15 AM - edited 03-05-2019 07:21 PM
RealPlayer does not seem to work behind firewall. WMA streaming works fine.
11-04-2007 03:30 AM
I think this maybe an MTU issue. Try reducing the MSS on the internal Interface
Interface Vlan1
ip tcp adjust-mss 1452
And perhaps then if you are using a dialer interface for PPP connnections try this command
Interface dialer 1
ip mtu 1492
Please rate posts
Stephen
11-04-2007 06:44 AM
I'm trying to get some more information.
I found that this happens only with some of stream providers. It's not about RTSP yet, the problem occurs during negotiation. The server responds with HTTP 400 ('bad request'). And the most puzzling thing is when I swtiched the default browser from Firefox to Internet Explorer, it start working. But this is not the solution. I want to make it working with any default browser.
I'll rate all answers when I get my problem resolved.
Thank you for the reply.
11-04-2007 08:12 AM
Sorry for disturbing. It appears not a Cisco router problem. It was a problem with the default browser.
Thanks for your help!
