UDLD and Loop guard
Nov 4th, 2007
Cisco Recommends to enable UDLD on etherchannel and Loop Guard on Non designated ports(Root and backup) . if there are 2 core with STP loadBalancing so the EtherChannel will be No-designated for some vlans So my questions is that Can i enable both of UDLD and Loop Guard on the etherchannel ports?
bvsnarayana03 Sun, 11/04/2007 - 21:03
UDLD & loopguard are the methods of preventing abnormal conditions in stp due to unidirectional communication. When udld is enabled on interface, it sends udld pkts & waits for the response from connectd neighbor. If its not recvd, udld considers the interface as unidirectional & shutdown.
Manual intervention required to make the port operational.
Loopguard on the other hand, puts the port in loop-inconsistent state in case of unidirectional condition i.e. when bpdus are sent but not recvd. When the port starts recving the bpdus, again stp calculation is run & port is transitioned to a suitable state. no manual intervention required. Loopguard only aplies to active vlan instances on the port.
Hope that clarifies, which option is better.
welcomeccie Mon, 11/05/2007 - 02:09
Core1 ---Etherchannel----Cor2
|-------Edge1------------
Thank you for your reply .But can i apply both of the UDLD and Loop guard on the etherchannel?
bvsnarayana03 Mon, 11/05/2007 - 02:59
my thought is to have loopguard, as there is no manual intervention required.
welcomeccie Mon, 11/05/2007 - 03:54
But cisco Recommends to use UDLD in etherchannel and use desirable mode too so can i apply loop guard too with UDLD
I appreciate your reply
