CCNA 802 Homelab Help
Nov 4th, 2007
Does anyone know what type of routers you need for the new CCNA 802 home lab. I have two 1720s and I dont have a lot of money to spend right now. I also have the Routersim Network visualizor 5.0 for the 801. Can I get another 1720 and maybe a switch. Will that be enough. I mean I'd love to have more but I can't afford it now. Any suggestions?
Overall Rating: 1 (1 ratings)
rscarborough63 Mon, 11/05/2007 - 01:05
Thanks, this helps a lot. Like I said I already have 2 1720s but I'm trying to decide if I should get another router or switch. I was thinking of using the simulator for the switch stuff. I will have to check my budget, thanks I really appreciate your help.
