QoS over IP-MPLS network
Nov 4th, 2007
Hello! I'm trying to do a lab at my university implementing QoS at IP-MPLS networks. You can see y topology at the picture. I have running MPLS at each router in every serial interface. I'm trying to set the packets from the FTP server with mpls experimental = 0 at the New York router and match it at Dallas but I doesn't work. This is what I'm doing:
At New York:
Input configuration:
NEW_YORK(config)#class-map FTP
NEW_YORK(config-cmap)#match input-interface ethernet 0/0
NEW_YORK(config)#policy-map NYFtpIn
NEW_YORK(config-pmap)#class FTP
NEW_YORK(config-pmap-c)#set qos-group 1
NEW_YORK(config)#int eth 0/0
NEW_YORK(config-if)#service-policy input NYFtpIn
Output configuration:
NEW_YORK(config)#class-map qosgroup1
NEW_YORK(config-cmap)#match qos-group 1
NEW_YORK(config)#policy-map NYFtpOut
NEW_YORK(config-pmap)#class qosgroup1
NEW_YORK(config-pmap-c)#set mpls experimental topmost 0
NEW_YORK(config)#int s0/0
NEW_YORK(config-if)#service-policy output NYFtpOut
Them at Dallas:
DALLAS (config)#class-map MPLSEXP0
DALLAS (config-cmap)#match mpls experimental topmost 0
DALLAS (config)#policy-map DallasFtpIn
DALLAS (config-pmap)#class MPLSEXP0
DALLAS (config-pmap-c)#set qos-group 1
DALLAS (config)#int s0/0
DALLAS (config-if)#service-policy input DallasFtpIn
DALLAS (config)#class-map qosgroup1
DALLAS (config-cmap)#match qos-group 1
DALLAS (config)#policy-map DallasFtpOut
DALLAS (config-pmap)#class qosgroup1
DALLAS (config-pmap-c)# HERE I WANT TO USE PRIORITY COMMAND BUT I TRIED WITH DROP AND DOSEN'T WOK
DALLAS (config)#int s0/1
DALLAS (config-if)#service-policy output DallasFtpOut
Any information will help. I think it can be some problems with the labels or something. You can see the mpls forwarding table at the picture. Thank you very much!!!!
