Applying PBR route-map
Nov 4th, 2007
I have a L3 Switch connected to 2 routers. I want to send all traffic sourced from 10.10.10.10 to router 1 and all traffic sourced from 10.10.10.20 to router 2.
Where would I apply this route-map?
The L3 switch has an interface vlan 10 (10.10.10.1). Would I apply it to this interface?
Overall Rating: 4 (2 ratings)
Richard Burts Sun, 11/04/2007 - 20:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Sparky
In general the route map is applied on the interface where the traffic to be policy routed enters the device doing PBR. So we would need some additional information about how you have configured PBR to be able to really answer your question correctly. If you want to route traffic sourced from 10.10.10 then it would probably make sense to apply a PBR route map to the interface where 10.10.10 is connected. If you also want to PBR 10.10.20 then we would need to know where 10.10.20 is connected and how the route map was configured.
Rick
bvsnarayana03 Mon, 11/05/2007 - 00:28
  • Silver, 250 points or more
I understand that ur hosts mentioned in question are connected to VLAN 10 on L3.
You need to apply the route-map to this VLAN interface & specify each routers Ip as next-hop in set statement of route-map.
