VLAN Help
Nov 4th, 2007
Plzzzz help with configuration....
I have L3 switch 4506 and we need to create 5 VLANS on it.
VLAN Admin
VLAN Finance
VLAN Server
VLAN User
VLAN Management
Our requirement is -
<1> Finance-VLAN to communicate with Server-VLAN only
<2> Management-VLAN to communicate with Admin-VLAN
<3> Other VLAN's can communicate with each other.
bvsnarayana03 Mon, 11/05/2007 - 00:22
  • Silver, 250 points or more
If u create L3 VLANs with separate subnet assigned to each VLAN, u can restrict communication by applying ACLs to each L3 VLAn .
zara_linux Mon, 11/05/2007 - 07:48
Can you let me know the steps how to restrict communication between VLANS.
We want oto use OSPF as the routing protocol, so what config is required for this..
Hieu Cao Mon, 11/05/2007 - 12:06
You can try this:
config t
int vlan 10
description Admin VLAN
ip address 192.168.10.1 255.255.255.0
int vlan 20
description Finance VLAN
ip address 192.168.20.1 255.255.255.0
int vlan 30
description Server VLAN
ip address 192.168.30.1 255.255.255.0
int vlan 40
description User VLAN
ip address 192.168.40.1 255.255.255.0
int vlan 50
description Management VLAN
ip address 192.168.50.1 255.255.255.0
In the switchports of the 4506, use:
int fa0/1 (whatever port)
description Server Only
switchport mode access
switchport access vlan 20
switchport access vlan 30
int fa0/2
switchport access vlan 10
switchport access vlan 50
inf fa0/3
description Other VLANS
switchport access vlan 40
Make sure that you assign workstations/servers to the right switchport, and check IP ROUTE is correct.
hth,
hieu
zara_linux Mon, 11/05/2007 - 21:36
tell me,
Dont I need a routing protocol to route traffic between vlans... If I need then how can I configure OSPF for my requirement.
