how to segerate traffic
Nov 5th, 2007
I've two leased lined configured in the same router.I've 11 VLANs configured. I want to use the 2nd link for Lotus notes traffic and web traffic of admin VLAN and rest of the trqaffic should be forwarded to the fist Link.
how to segerate the traffic plz suggest.
paul.matthews Mon, 11/05/2007 - 12:10
  • Silver, 250 points or more
As suggested Policy based routing will do the job, but you could also consider using VRF-Lite to create two logical routers and separate that way.
mujahidpasha Mon, 11/05/2007 - 21:00
paul thanks
thats true
plz suggest how to do that
m not too advance
please give me some conf example
paul.matthews Tue, 11/06/2007 - 00:27
I think I made a couple of suggestions - which are you looking for an example of?
ohassairi Tue, 11/06/2007 - 01:44
here is a sample of PBR. routing is based on TCP port
http://hassairi.50megs.com/#portr
but what about the return path: are you sure the packets will return from the link they used to go out?
