firewalls
Nov 5th, 2007
Hi all, is one of the main functions of a firewall to basically create a dynamic access list, so that if something originates from inside for example, that traffic is automatically let back in ?
mikeallison Wed, 11/07/2007 - 19:29
Hi Carl.
Its been a while since I messed around with ACL's, however, I believe you need to enter the "established" command after the ACL rule, so any connections that go out will be allowed back in if they are already established.
EG: (Grabbed from http://www.networkclue.com/routing/Cisco/access-lists/index.aspx)
Assumptions:
internal network: 63.36.9.0
access-list 101 - Applied to traffic leaving the office (outgoing)
access-list 102 - Applied to traffic entering the office (incoming)
ACL 101
access-list 101 permit tcp 63.36.9.0 0.0.0.255 any eq 80
ACL 102
access-list 102 permit tcp any 63.36.9.0 0.0.0.255 established
Hope this helps.
Michael.
carl_townshend Thu, 11/08/2007 - 01:46
is this for routers or firewalls ? I wanted to know the way in which the asa monitors the outbound sessions then allows them back in, bascially how the firewall works ?
