How to check max config on Cisco Routers?
Answered Question
Nov 5th, 2007
I would like to know the maximum config i can write on Cisco Routers. How can i compare current running config with memory?
Kindly help me in this regard.
Correct Answer by Kevin Dorrell about 9 years 4 months ago
Do a show startup-config.
The first line will show you something like "Using 15735 out of 245752 bytes".
If you have a problem with the size of the config, you can compress it by configuring service compress-config
Kevin Dorrell
Luxembourg
Correct Answer by Phillip Hichens about 9 years 4 months ago
The maximum config depends on your specific hardware. I've worked on routers with more than 32000 lines of config.
The "dir system:" command will show you the size of your running config.
Use the "show archive config differences system:running-config nvram:startup-config" to compare the config, if this was what you were trying to get at.
Maybe you can give us more clarity on your problem.
Phillip
Overall Rating: 5 (2 ratings)
Correct Answer
Phillip Hichens Mon, 11/05/2007 - 05:02
Phillip
Correct Answer
Kevin Dorrell Mon, 11/05/2007 - 05:03
  • Green, 3000 points or more
Kevin Dorrell
Luxembourg
