AP1242AG in bridge mode
Answered Question
Nov 5th, 2007
Dear Sirs.
I'm trying to configure two 1242AG access points in order that they operate in bridge mode.
I set the role of my first AP as Root bridge, when I set the role of the second to non-Root bridge. After this I see that 802.11g interface of the second AP is down, however, I also see that it is enabled. Therefore, APs are not bridging.
Please advise.
Correct Answer by andrew.brazier@... about 9 years 6 months ago
Good news, don't forget to award points if my post was helpful. : )
Overall Rating: 3 (1 ratings)
andrew.brazier@... Tue, 11/06/2007 - 08:09
  • Bronze, 100 points or more
First thing to try is to remove all security and see if the non-root bridge will then associate. If so, rebuild the security and test again.
Are there any errors logged on either bridge?
The radio on the non-root will be down until it associates with the root.
AlexioUBS Thu, 11/08/2007 - 01:56
Removed the security, set SSID used for bridging to Infrastructure SSID and everything begin to work (then implemented WPA-PSK security to bridge link - works OK).
Correct Answer
andrew.brazier@... Thu, 11/08/2007 - 02:02
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
