Restoring Unity - Disaster Recovery Scenario
Nov 5th, 2007
Hi all,
I've been thinking about how to recover a unity server in a disaster recovery scenario...
At a high level I would:
- Rebuild the server via the normal installation process
- Restore from tape the Exchange Message store
- Restore from tape backup the SQL Data Store
I'm thinking I might also have to restore the system state as well but I'm not certain on that one.
Can anyone advise on the appropriate steps?
Overall Rating: 5 (1 ratings)
sopayne Mon, 11/05/2007 - 16:17
The supported method is covered in the Reconfiguration and Upgrade Guide:
DiRT should be included in the Cisco Unity Tools Depot under Administrative Tools, but can also be downloaded from here:
These instructions should get you where you need to go.
I hope this helps.
