ajagadee Mon, 11/05/2007 - 08:48
  • Cisco Employee,
Cisco IPSec Client does not support 64-bit. If the user requires 64-bit support, the upgrade path is to use the Cisco AnyConnect VPN Client instead, which does support 64-bit. Note that the AnyConnect Client supports only SSL VPN connections (CSCsi26069).
Please refer the below URL for details:
http://www.cisco.com/univercd/cc/td/doc/product/vpn/client/5_0/50client.htm#wp1542293
VPN Client Support Matrix
http://ftp-sj.cisco.com/cisco/crypto/3DES/vpn/client/vpn-client-support-matrix-v2.0.htm
Release Notes for AnyConnect VPN Client, Release 2.0
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect20/release/notes/cvcrn200.html
Arul
Please rate helpful posts
Phillip Remaker Fri, 02/19/2010 - 11:22
  • Cisco Employee,
February 18, 2010
Due to popular demand, the Cisco VPN Client v5.0.7 open beta is now available!
In addition to serving as a general maintenance release, the Cisco VPN Client 5.0.7 beta is compatible with Windows 7 & Windows Vista 64-bit environments.
A 64-bit specific compatible image is available for installation on these platforms.
Please have communicate feedback (both positive and problems) to [email protected].
Key Capabilities available for Beta Testing:
New Platform support – Windows 7 & Windows Vista 64-bit platform compatibility
Software Access: http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=281940730 (under 5.BETA)
Software is available for download by any customer with a Cisco.com SMARTnet™ enabled login.
Release Notes will be available next week via a link once the download image is selected.
