Quick NAT question
Nov 5th, 2007
I am implementing a new network and ip subnet where I work. The problem is that one User needs to have a static IP to our mother corporation but I cannot get the static NAT to work. My question is, will having this;
nat (inside) 1
With multiple addresses for PAT conflict with this static NAT;
static (outside,inside) netmask
and if so does anyone have any suggestions on how I can work around this?
My recollection is - it's been a while - that the PAT rule takes precedence, so you will need to use an ACL to deny the host then permit the net.
Such as:
Overload rule:
access-list overload deny
access-list overload permit
Then build your nat rules
nat (inside) 1 access-list overload
Lastly build your static rule.
Think that should do it; I don't have a Pix in front of me right now to try it on.
ajagadee Tue, 11/06/2007 - 12:02
The static (outside,inside) netmask should be
static (inside, outside) netmask
Do a clear xlate after you configure the static NAT and test it.
