Problems with bre-connect stability
Nov 5th, 2007
I'm having a simple bre-connect configuration as follows:
6500A#
vlan 70
interface ATM9/0/0.70 point-to-point
pvc 0/70
bre-connect 70
Then I transit this vlan to another device where I assign it as an access port:
6500B#
vlan 70
int fa 0/1
switchport
swtichport access vlan 70
switchport mode access
The problem I'm having is that I'm running OSPF over this path on the CPEs. In some situations I can not ping from CPE to CPE. If I create an "interface vlan 70" in router A I get pings back but then OSPF does not work. If I remove the "int vlan 70", then, I get pings and OSPF until the next time when it stop forwarding traffic again.
Anyone has any idea on what might be a workaround with this issue? Anything missing?
-W
