ASA 5520 hardware reset
Nov 5th, 2007
  • Gold, 750 points or more
I'm not sure if the problem is related to hardware - when i connect to the asa via hyper terminal i dont get any responses from the asa. the power LED is green but the vpn is amber. we have the reset button at the back of the unit - is the reset button useable or is it just there for future uses?
Overall Rating: 4 (1 ratings)
francisco_1 Tue, 11/06/2007 - 01:28
done that Arul - looking at the asa front panel now, the only LED that is fully green is the VPN, nothing on the power LED and the status and active are amber. - strange.
francisco_1 Wed, 11/07/2007 - 01:12
sorted- i removed the flash card from the asa motherboard and put it back in - the asa is now booting properly.
ajagadee Wed, 11/07/2007 - 09:01
  • Cisco Employee,
Thanks for the update on the solution.
Arul
