Dialed number on CDR
Nov 5th, 2007
How to dump dialed number on CDR Table? I see that to dump only the result from route pattern. Ex: 8.55121200 (predot) the result is 55121200 wich is on CDR table. Anyone help me?
heathrw Tue, 11/06/2007 - 12:57
Terminal Services into your Call Manager start SQL Query Analyzer which should start a blank query copy/paste between the start finish. Use the web page to replace the two strings of numbers (epoch time) start date/time finish date/time. Check if this matches up with what you are after. Use the Play button to execute query.
Hope this helps, let me know how it goes
--START--
USE CDR
SELECT callingPartyNumber AS CallingNumber, originalCalledPartyNumber AS CalledNumber
FROM CallDetailRecord
WHERE (dateTimeOrigination > 1180310400 AND dateTimeOrigination < 1180396799)
--END--
http://www.onlineconversion.com/unix_time.htm
eduestme2 Wed, 11/07/2007 - 05:36
Thanks for the query! The question is: How to save on cdr the real dialed number? On CDR is save the result from route pattern.
Anyone help me?
Thanks!!
