11-05-2007 11:19 AM - edited 03-09-2019 07:14 PM
I have been quoted for a ASA 5520 with AIP-SSM-20 and one with AIP-SSM-10 what is this?
11-05-2007 12:28 PM
Andy
The AIP-SSM-10 and the AIP-SSM-20 are optional modules that can be installed in some of the ASA5500 models. They are used to help the ASA do Intrusion Prevention without loading down the CPU of the ASA. the -20 has more processing power than the -10 and will handle a larger volume of traffic.
Rick
11-05-2007 12:44 PM
Thanks, I will be getting the ASA 5520, how can I tell if the -10 or the -20 ips add on is the one I need? We have a 10mb internet line, with 4 web servers and many VPNs
11-05-2007 12:54 PM
Andy
This link has a chart which provides some information and some comparisons of the various models:
http://www.cisco.com/en/US/products/ps6120/prod_models_comparison.html
Based on the description I would think that the -10 would be sufficient for your requirements.
Rick
11-05-2007 01:08 PM
Thanks, does it just mean the amount the IPS can handle at any one point before there is a performance dip? I will have some DMZ's but via a vlan switch of one of the ports too and tag the VLANs, not sure if that will change your result? The DMZ's will be just othe networks
11-05-2007 01:39 PM
Andy
I do not believe that it changes the results.
Rick
06-12-2009 10:02 AM
hi experts,
I have AIP SSM-20 and i need it to be configured....so pls help me out giving me basic configuration and customized document to make it up .....thanks in advance...
06-15-2009 01:42 PM
pls help me.......giving me configuration guide with initial steps and allowing traffic to pass over it....if any thing more i need to configure regarding AIP SSM module u may guide me pls.....
