Display Called ID
Nov 5th, 2007
I'm using CM6. Does anyone know how to make the phones (7941) dispay the Called ID? Is it even possible? When I call an internal extension, can it tell me the name of the person I called?
Thanks.
See K. Lee
Overall Rating: 5 (1 ratings)
smahbub Mon, 11/12/2007 - 12:44
  • Silver, 250 points or more
Yes it is possible, but it should be done in CCM Admin login.
mciarfello Mon, 11/12/2007 - 13:11
Should be the DISPLAY parameter in the phone's LINE setting. You probably set the ALERTING parameter also.
The IP Phone (say X) making a call to IP Phone Y should display where 1234 is the called extension
To: person's name
(1234)
The above is for internal calls only. If you need do to this for calls from the outside, that's a different story. Let us know and we can help.
