CSM 3.1 and Performance Monitor
Nov 5th, 2007
I have CSM 3.1 up and running and am trying to get Performance Monitor running so we can monitor the VPNs. When I try to install it I keep get file ting the message:
"One instance of CiscoWorks Installation is already running. If you are sure that no other instances are running, remove the file C:\cmflock.txt. This installation will now abort." Why can't I install this. I am also running AUS server on the same box, which should be just fine. Also, the Cisco Works licensing says there is no licence, however I have CSM licences correctly, could that have something to do with it?
Anonymous (not verified) Mon, 11/12/2007 - 12:54
This issue is related to this bug: CSCsd79426 : you need to edit the snmp settings file:
Mahmoud Nofal Tue, 11/13/2007 - 01:26
I face many bugs in the CSM 3.1 and all were fixed after installing CSM 3.1.1!
try it...
krowland123 Tue, 11/13/2007 - 06:06
Upgraded to 3.1.1 and it still wouldn't work. Ended up being a file that was supposed by automatically deleted after CSM was installed.
