Can I replace a 3550 with a 4948-10ge
Nov 5th, 2007
Can I use a 4948-10ge switch as a direct replacement for a 3550 switch. I'm concerned about the 10 gig uplink port on the 4948. Can it connect to a 1 gig gbic port on a 6509? Is there anyway to make this work?
thanks
owillins Mon, 11/12/2007 - 14:42
  • Silver, 250 points or more
you can replace the switch , but enable the proper configuration between the 4948 and 6509 switches ie speed , trunk modes, MTU , timer settings etc.
