VRF-Aware IPSec for Remote Access
Answered Question
Nov 5th, 2007
Dear All,
Has anyone successfully implemented VRF-Aware IPSec for Remote Access ?
I am trying to implement this feature on a PE which has MPLS enabled
on the Internet facing interface.
With the config below, I am being able to establish an IPSEc tunnel but not being able to PING the VRF interface configured on the same PE.
I will be really grateful for any comment or any pointers for what could
be possibly wrong with the configuration below:
aaa new-model
aaa authentication login USER-AUTHENTICATION local
aaa authorization network GROUP-AUTHORISATION local
crypto keyring test-1
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group test-1
key test-1
domain test.com
pool cpe-1
acl 101
crypto isakmp profile test-1
vrf test-1
keyring test-1
match identity group test-1
client authentication list USER-AUTHENTICATION
isakmp authorization list GROUP-AUTHORISATION
client configuration address initiate
client configuration address respond
crypto map IPSEC-AWARE-VRF 2 ipsec-isakmp dynamic test-1
ip local pool cpe-1 192.168.81.1 192.168.81.254 group test-1
crypto dynamic-map test-1 1
set transform-set test-1
set isakmp-profile test-1
reverse-route remote-peer
interface GigabitEthernet4/0/0
ip address x.x.x.x 255.255.255.240
ip router isis
mpls ip
Customer facing interface
interface GigabitEthernet1/0/0.1
encapsulation dot1Q 100
ip vrf forwarding test-1
ip address 110.110.110.1 255.255.255.0
Kind regards,
ZH
Correct Answer by ivillegas about 9 years 6 months ago
Try disabling CEF in the physical interface or remove the subinterface from the same vrf as the crypto map. There is a bug regarding this CSCeb65521.
Overall Rating: 4.5 (2 ratings)
Correct Answer
ivillegas Mon, 11/12/2007 - 14:44
  • Silver, 250 points or more
zahid.hassan Tue, 11/13/2007 - 03:12
Million thanks for this.
This now works after disabling CEF on the public facing interface.
Zahid
