MetroE Route Setup
Nov 5th, 2007
I need some help. I need to configure 2 3560's to route to each other connected via a MetroE PtP setup with a dot1g tunnel. One side uses a firewall for its gateway, the other needs to use the route on the switch for its default gateway. I would like the IP for side A (with the firewall) to be 192.168.0.1 and side B to be 192.168.1.1. Any help would be great. If it would be easier to trunk, please let me know.
owillins Mon, 11/12/2007 - 14:46
  • Silver, 250 points or more
From Switch_A when you send dot1q tagged frames, they will be received by the dot1q-tunnel port on Switch_B. And the dot1q-tunnel port on Switch_B will be a part of a VLAN, let's say for example VLAN 100. All the dot1q-tagged frames coming from CatSwitch_A will be again (double) tagged with this VLAN 100. Better you implement the static routes .
