Configuration Archive in CSM 3.1.0
Nov 6th, 2007
Is there a way to have the configurations of devices which are managed by CSM? Is it possible to have a back up of this information or to launch a job to do this?
Thank you,
koltl-gold Fri, 11/09/2007 - 08:01
I guess they are stored automatically. If you open Deployment Manager and search back some old deployment, you can see the archive config.
lcuchisanmillan Mon, 11/12/2007 - 00:36
I would like to export all the configurations in case of troubles in the machine where it is installed the CSM.
dradhika Mon, 11/12/2007 - 20:24
Tools -> Config Archive stores all the discovery and deployed configuration of a device.
It supports the rollback option too.
Can you check if that is what you are searching for?
