CISCO 4500 - need help on MSFC
Nov 6th, 2007
I need to change my Catalyst 6500 at my DR site.
Here are the module I have inside :
Mod Slot Ports Module-Type Model Sub Status
1 1 2 1000BaseX Supervisor WS-X6K-SUP1A-2GE yes ok
15 1 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
4 4 48 10/100BaseTX Ethernet WS-X6348-RJ-45 no ok
9 9 48 10/100/1000BaseT Ethernet WS-X6148-GE-TX no ok
I am thinking of buying a 4500 Series.
However I don't know how to choose the right Supervisor and the MSFC.
Is there any supervisor card with MSFC onboard ? is a PFC always onboard ?
How do I see in the doc that the Supervisor have MSFC onboard ?
Many thanks for your guidance.
lgijssel Tue, 11/06/2007 - 04:43
Could you perhaps elaborate a bit about WHY you need to change the 6500?
What are the requirements for the new switch?
Is upgrading the supervisor not an option?
trombidz1 Tue, 11/06/2007 - 04:50
We would like to change this 6500 to use the part as spare for my Primary site.
This has been budgeted so need to spend the money . Anyway.
I will install 2 1000Base Ethernet card to connect my servers, pc's and printers.
I will have a couple of static routes . I redistribute them with EIGRP. and I will learn all my companie group routes via EIGRP also from my provider router ( we use a MPLS )
nothing else
what other requirement should I be focused on ?
lgijssel Tue, 11/06/2007 - 04:58
"what other requirement should I be focused on ?"
Just mentioning three:
-Support for 10Gb links
-Cost (seems to be the least of your worries;-)
Still a 4500 series solution can do the job for you.
trombidz1 Tue, 11/06/2007 - 05:02
My problem is how to choose the correct Supervisor ? also are msfc always on board ?
trombidz1 Tue, 11/06/2007 - 05:59
Sorry , I would like to be more precise :
We have actually on the supervisor, an msfc card attached to get layer 3 routing protocols.
So as far as I understand , on the Supervisor doc , when they say Layer 2/3/4 services , that means the supervisor already as the capabilities of bulding routable table , correct ?
