UCCX 4.5 Historical Reporting
When trying to log into the historical reporting client I see the following message:
"Failed to login to database. Ask your administrator to check the database user id a password that is dynamically obtained from the application server."
I think this is something to do with the db_cra database login but I don't know what to do about it.
Any ideas?
smahbub Tue, 11/13/2007 - 06:51
  • Silver, 250 points or more
Resolution:
Reset 'db_cra' SQL user password back to 'db_cra'.
CSCO11117246 Wed, 11/14/2007 - 04:54
how do you Reset 'db_cra' SQL user password back to 'db_cra'?
regi_firnanda Tue, 09/01/2009 - 19:00
Did you change the SQL Server authentication mode ?
Because the problem usually happens when you change the SQL Server authentication to "Mixed Mode".
Sheraz Saeed Lodhi Mon, 09/07/2009 - 17:15
Go into Sql Sever > enterprise manager
Select the machine your database is running on which. Right click and slect properties option.
properties > Security > Authentication > Slect Windows only. Restart Sql server engine then try.
