CallManager: block routing of GSM calls to a GSM Box if a timer is reached
Nov 6th, 2007
Hello!
I have a CallManager and a GSM Box with one SIM inside.
The GSM Box is attached to the VoiceGW by a FXO card.
The SIM has 900 free minutes/month, after which GSM calls are "expensive".
I' like to block routing of GSM calls to the GSM Box if the timer of 900 minutes is reached.
Unfortunately, the GSM Box is "stupid" (it isn't configurable).
Is there a way to do that directly on the CallManager configuration?
Thanks in advance for your help!
Anonymous (not verified) Tue, 11/13/2007 - 06:56
The route filter can only be applied to a .@ pattern. In your situation, the easiest thing to do would be to create a route pattern and assigned to a block partition. Apply the css w/ block to a user you want to avoid calling specified string. Create pattern you wish to block and on this pattern assign to partition X. Create CSS which lists partition X and assign this CSS to users which you wish to block for specified dial string
