11-06-2007 05:14 AM - edited 03-15-2019 07:05 AM
I can ping the call manager but not connect with:
I believe it sits on a Cisco MCS 7800 Series Media Convergence Server.
Do I reboot the server?
11-06-2007 05:48 AM
Hi Mort,
Just a thought here, but have you tried;
If that doesn't work I would probably try a reboot (after hours of course :)
Hope this helps!
Rob
11-06-2007 06:00 AM
Two things.
1) Make sure IIS server service has been started.
2) Use IE 6.0 browser with SP2 for IE installed
hth,
Ajaz
pls rate this post if it helped.
11-06-2007 06:21 AM
Browser IE 6 has worked in the past.
Could not connect to box with RDP.
