6513 VMPS server
Nov 6th, 2007
Hi, we are using a 6513 as a VMPS server. How many MAC addresses can I have maxiumun on the Server, or is there no limitation?
Thanks in advance and regards
Thomas
owillins Tue, 11/13/2007 - 07:06
Maximum MAC addresses and VLAN depends upon the platform and its software you are using.
VMPS enables the dynamic assignment of switch ports to VLANs, based on the source MAC address of the device connected to the port. When a host is moved from a port on one switch in the network to a port on another switch in the network, the switch dynamically assigns the new port to the proper VLAN for that host.
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/6.x/configuration/guide/vmps.html#wp1019985
