Ether channel
Nov 6th, 2007
I have two switch connected with each other with two link and i configured the Layer 2 etherchannel on both the switches and ehterchannel status shows up/up, now i have loopback interface 0 on both the switches on switch A i have ip for loopback is and on siwthc B i have loopback ip now how can i make reachability to both the subnet do i need any kind of routing there?
bernardwanyama Tue, 11/06/2007 - 12:41
You need to have a common subnet between the two switches e.g vlan interfaces or layer 3 ports, or even turn the etherchannel into a layer 3. Then you put in static routes or use a routing protocol to advertise the loopbacks plus any other networks.
As to which approach is more optimal, I do not have an authoritative answer.
Kind regards,
dangal.43 Tue, 11/06/2007 - 19:31
I assigned same subnet on the both the switch, i tried L2 etherchannel with access as well as on trunk too but its not working!
bvsnarayana03 Wed, 11/07/2007 - 03:00
What is the exact requirement. Yes u'll have to run routing protocol for reachability to loopback from other switch.
A precise requirement may help us provide exact solution.
