Restricting access to PSTN/Telco Lines
kelloggs4life
I have a client that has CME 4 installed on a router and they use 7921 I phones. There are 4 PSTN lines connected to the router allowing users to make external calls. The configuration is such that 2 of these lines ring out at specific users extensions while the other 2 ring out at the receptionist's desk. When users want to make external calls, they are able to use any of the available 4 lines at random.
The client now wants access restricted on the 2 first lines that ring out at 2 different users extensions such that calls going out and coming in on these lines are tied to the respective extension of the user. Access however is still granted to all users on the other 2 lines.
Can someone please help with a sample config or a how to go about this?
Please see the router config attached. I have used thr trunk command here but its still not working, what am I doing wrong?
Femi
unfortunately a voice port can belong to only one trunk group, but multiple voice ports can belong to the same trunk group.
Therefore it would not be possible to configure two specific trunk groups, one with only two of the voice-ports and another trunk group with all four voice-ports.
One possible option which comes to mind involves reconfiguring the COR lists as described below:-
Firstly configure two separate distinct dial-peer COR Lists for each pattern for both sets of phones. For example:
dial-peer COR custom
name Set1-Call-Local
name Set2-Call-Local
dial-peer cor list Set1-Call-Local
member Set1-Call-Local
dial-peer cor list Set2-Call-Local
member Set2-Call-Local
dial-peer voice 1 pots
corlist outgoing Set1-Call-Local
description ** FXO pots dial-peer **
destination-pattern 9T
preference 1
port 0/0/1
dial-peer voice 2 pots
preference 2
port 0/0/2
dial-peer voice 3 pots
corlist outgoing Set2-Call-Local
preference 1
port 0/0/3
dial-peer voice 4 pots
preference 2
port 0/0/2
dial-peer voice 5 pots
preference 3
port 0/0/1
preference 4
port 0/0/0
dial-peer cor list Set1-user-local
dial-peer cor list Set2-user-local
You can then assign the ephones-dn to the appropriate incoming COR list to either one of the above.
This will enable users assigned to Set2 for example to be able to dial-out across all four voice-ports, whereas set1 can only dial-out across two.
In the example I have changed the order of the ports for Set2. This is simply to ensure that outbound calls do not necessarily tie up the ports specifically for Set1.
Pls rate this post if you find it helpful.
Allan.
15 Replies 15
paolo bevilacqua
what is not working, incoming or outgoing ?
What happens when the press the line button ?
preference 1
port 0/0/1
preference 2
port 0/0/2
preference 1
port 0/0/3
preference 2
port 0/0/2
preference 3
port 0/0/1
preference 4
port 0/0/0
Allan.
Hi Allan,
Technically, COR is not necessary in this case.
Let's recall that when DPs is used with trunkgroup, one can specify multiple trunkgroups with different priorities.
So for example, DP 82 (created for "trunk" command", would use first a trunkgroup made of the preferential lines, then the other one.
Note, that is necessary only to give the preferential users access to a second line. If that is not desired, no multiple trunkgroups are necessary.
Hi Allan,
I was just going through you suggestions here and i also identify with it. But like i said, I will try out PB's suggestion first but if i am to try out yours, i was thinking i would need to create 3 trunk groups and not 2. 1 each for the 2 private lines and the 3rd for the rest of the users.
Please see below the config i plan to use:
name set3-call-Local
dial-peer cor list Set3-Call-Local
member Set3-Call-Local
preference 1
port 0/0/0
preference 2
port 0/0/1
preference 1
port 0/0/2
corlist outgoing Set3-Call-Local
preference 1
port 0/0/3
dial-peer cor list Set3-user-local
This config I believe will restrict access to ports 0/0/0 and 0/0/1 for the respective users while ports 0/0/2 and 0/0/3 will be picked on random by the other users.
My headache though is how to fit this into the present configuration i have on the router.
Femi
I still think using 'trunk XX' under ephone is simpler than COR. With that you will have two dedicated DPs each one with the matching XX as destination-pattern and the corresponding port.
Then put 0/0/2 and 0/0/2 in a trunkgroup and reference it for for the DP with '9T' as destination pattern.
Then use COR only to limit call as necessary, unrelated to the preferential lines mentioned above. From you inital config, I think your COR config can be simplified a lot.
Hi PB,
I honestly am looking for the easier and faster way out.
Using 'trunk XX' under ephone - how do u go about that? Is it any different from my present config?
Kindly take a minute to look at what I have in my attached router config.
"Then put 0/0/2 and 0/0/2 in a trunkgroup and reference it for for the DP with '9T' as destination pattern" ???
Femi
Hi Femi,
I glanced over your config, but honestly is not possible to go into a deep "off-line" analysis.
My sentence above is about placing the lines not reserved in a trunkgroup that is accessed by everyone with 9.
Hope the indications given can put you on the right track, then it's also a matter of trial and error.
good luck!
What is not working is that all users when they wanna make external calls use any of the 4 PSTN lines available. This is not supposed to be so. Only 2 lines are supposed to be available to all users. The other 2 lines are direct lines which are to be restricted for use by only the users, incoming and outgoing. Calls to the 2 private lines terminate on the IP phones of the respective users, but when either of the 2 users try to make calls, they tend to use any of the 4 lines available in the company instead of strictly using their own private lines.
I'm sorry, i dont know what line button you are referring to?
the simplest and most effective approach is to trunkgroup:
voice-port X/0
trunk-group pstn
voice-port X/1
trunk-group pstn
dial-peer voice 100 pots
trunkgroup pstn
repeat the DP for as many specific destiantion-pattern you have.
Do not place the "reserved" lines in trunk group and these will never be used.
This will simplfy you config a whole lot.
Note, you might need COR in case users get to know the access codes used for "trunk" under "ephone-dn" and try to use them anyway.
Never mind the line button, it just means, going off-hook for an ephone.
Hello guys,
Thanks a lot to both of you for your suggestions.
Taking a look at Allan's, it actually does look some what complex but I will try it out also.
Since the client wants this solution asap, i will go with PB's suggestions first to see if it works cos it actually does look simpler and I kinda identify with it easier that Allan's suggestions.
I will keep you both informed as soon as I carry out the config changes on the router.
Thanks again.
Femi.
HI PB,
"Do not place the "reserved" lines in trunk group and these will never be used."
Does this imply that all i need to do is specify 1 trunkgroup on 2 of the ports only (port 0/0/0 and port 0/0/1)? This implies access will be restricted to ports 0 and 1 for all users?
What about ports 2 and 3? How will each user of each of the 2 private lines be restricted to use his own line only?
Femi
for the ports tied to ephone-dn via trunk "trunk XX" command, you don't need to necessarily use trunkgroup, just port will be fine. But, if you want to give them the possibility of making a second call (albeit not on their reserved line that is busy already), you would then use trunkgroup and priorities, eg:
ephone-dn 20
trunk 80
number 20
ephone-dn 21
trunk 81
number 21
voice-port 0/0
trunkgroup 1st
connection plar opx 20
voice-port 0/1
trunkgroup 2nd
connection plar opx 21
voice-port 0/2
trunkgroup 3rd
voice-port 0/3
trunkgroup 3rd
dial-peer voice 20 pots
destination-pattern 80T
trunkgroup 1st 4
trunkgroup 2nd
dial-peer voice 21 pots
destination-pattern 81T
trunkgroup 1st
trunkgroup 2nd 4
dial-peer voice 22 pots
trunkgroup 3rd
I understand all that can seem confusing, but the result should be what you want.
I agree that this simplifies the configuration, the only issue as p.bevilacqua mentioned earlier is that the trunk access code can be used incorrectly.
This was the main reason for configuring the COR list example in a previous post. Having said that COR lists can be applied in either scenario.
Allan.
Hi Allan/PB,
Thank you both for your immense contributions. After taking time out to study both solutions offered, I was more at home with that which Allan put forward using COR list. Though i believe using PB's idea would make the whole config a lot simpler.
I have wrote configs for both solutions but I have only been able to test out the first one using COR list. It worked perfectly and I am quite glad for that.
Please see the config applied below:
name Set3-Call-Local
preference 1
port 0/0/0
dial-peer voice 10 pots
preference 2
port 0/0/1
dial-peer voice 17 pots
preference 1
port 0/0/2
dial-peer voice 24 pots
preference 1
port 0/0/3
ephone-dn 3 dual-line
number 1000
pickup-group 2
label IDY
description IDY
name IDY
call-forward busy 20
corlist incoming Set1-user-local
ephone-dn 4 dual-line
number 1001
pickup-group 1
label AKIN
description AKIN
name AKIN
call-forward noan 1000 timeout 20
ephone-dn 5 dual-line
number 1002 secondary 94627034
pickup-group 1
label AYO
description AYO
name AYO
corlist incoming Set2-user-local
ephone-dn 6 dual-line
number 1003 secondary 94627035
pickup-group 1
label TOYE
description TOYE
name TOYE
corlist incoming Set3-user-local
ephone-dn 7 dual-line
number 1004
pickup-group 2
label ACCT
description ACCT
name ACCT
ephone-dn 8 dual-line
number 1005
pickup-group 2
label BECKY
description BECKY
name BECKY
ephone-dn 9 dual-line
number 1006
pickup-group 2
label TIWA
description TIWA
name TIWA
ephone-dn 10 dual-line
number 1007
pickup-group 2
label WALE
description WALE
name WALE
ephone-dn 11 dual-line
number 1008
pickup-group 2
label OPE
description OPE
name OPE
ephone-dn 12 dual-line
number 1009
pickup-group 2
label BDEV
description BDEV
name BDEV
ephone 9
username "OPE" password 1008
mac-address 001B.5300.0910
paging-dn 1
type 7920
button 1:11
As you can see, contrary to what Allan initially suggested, I have 3 COR lists defined. 1 for each of the 2 private line users, the 3rd for the rest of the team.
Once again, thanks to both you guys. I definitely will be trying out the other config with PB's suggestion later on.
Cheers.
