Dial interface reset
Nov 6th, 2007
I have a problem where users are trying to dial in, but when the async interface comes up it shows interface reset. The async then immediately goes to down again:
*Nov 6 14:44:36: %LINK-3-UPDOWN: Interface Async0/1/0, changed state to up
*Nov 6 14:44:38: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async0/1/0, changed state to up
*Nov 6 14:45:20: %LINK-5-CHANGED: Interface Async0/1/0, changed state to reset
*Nov 6 14:45:21: %LINEPROTO-5-UPDOWN: Line protocol on Interface Async0/1/0, changed state to down
*Nov 6 14:45:25: %LINK-3-UPDOWN: Interface Async0/1/0, changed state to down
RT_01#
Nothing was changed on the config side of the router.
What could be the problem?
willemvw
willemvwyk Wed, 11/07/2007 - 03:40
From the user side, the modem dials, get the handshake, verify username and password and then when it gets to registering computer on the network, the connection drops. I had the line checked out and it is clean, ie no noise on the line.
I would also like to ask where I can get modemcap strings for the router? I see there is a basic modemcap string "&F1S02".
Any help/suggestions will be much appreciated.
regards
willemvw
