LMS 3.0 - CRC-error job
Answered Question
Nov 6th, 2007
I would like to start a job regularly to get the number of recent CRC-errors on specific devices. Is there a way to do this? Just running NetShow with 'sh int counters errors' doesn't give me the appropriate output. Do I possibly have to use a custom script?
I'm using CW LMS 3.0 for Windows
Greets
Correct Answer by Joe Clarke about 9 years 6 months ago
What you want to do will best be accomplished using the upcoming addition to LMS, Health and Utilization Monitor (HUM). HUM is best described as an MRTG-like plug-in for LMS which will allow you to create your own custom pollers then report on those pollers. A HUM demo will be included with LMS starting in December, but will be licensed separately.
In the meantime, CiscoView's Mini-RMON manager can show you CRC information for certain devices (mostly switches), but you cannot run periodic reports.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 11/06/2007 - 10:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Peter Fiers Wed, 11/07/2007 - 03:07
thank you for the quick answer. My manager though wants an instant solution without any effort. Is there any function in CW to read out only the CRC-error counter on a couple of devices, on a regular basis or not, and to get the result exported in a file - without having to configure rmon?
Greets
