Disabling the web interface
Answered Question
Nov 6th, 2007
Is it possible to disable the web interface on the MDS switches? If so do you know the commands?
Cheers
Richard
Correct Answer by andyhp1 about 9 years 7 months ago
You can use ACLs. The Cisco cook book has details. The commands will be something like,
mds-11-03# config t
Enter configuration commands, one per line. End with CNTL/Z.
mds-11-03(config)# ip access-list nohttp deny tcp any any eq port 80
mds-11-03(config)# ip access-list nohttp deny tcp any any eq port 443
mds-11-03(config)# ip access-list nohttp permit ip any any
mds-11-03(config)# interface mgmt0
mds-11-03(config-if)# ip access-group nohttp in
mds-11-03(config-if)# end
Overall Rating: 5 (1 ratings)
colin.mcnamara Tue, 11/06/2007 - 20:40
  • Bronze, 100 points or more
You should be able to apply an access list filtering this traffic to the mgmt interface.
Correct Answer
andyhp1 Fri, 11/09/2007 - 01:59
mds-11-03# config t
Trending Topics: Storage Networking
