Corporate Directory Rename,
Nov 6th, 2007
Can someone tell me how to rename the Corporate directory title on the IP phones when you hit the directories button.I would like to replace the word "Corporate" with the name of our company.
thanks
Mark
jbarcena Tue, 11/06/2007 - 08:10
Go to your CCM server and look for the xmldirectoryinput.asp that is under
C:\CiscoWebs\IPPhoneServices\CCMCIP
then change the name of Corporate Directory to your company's name.
//Jorge
mattcalderon Wed, 11/07/2007 - 13:36
Did you mean the xmldirectory.asp file? the xmldirectoryinput.asp contains the search functions. I want to alter the option #4 under directories. I did change the xmldirectory.asp file, but still the corporate directory option remained.
MCC
mattcalderon Wed, 11/07/2007 - 13:49
<%@ Language=JavaScript %>
function getBaseURL()
var scriptName = Request.ServerVariables("SCRIPT_NAME") ;
var endloc = String(scriptName).lastIndexOf("/") ;
var baseURL = "http://"+ serverName + String(scriptName).substr(0, endloc + 1) ;
return baseURL ;
try
var name = String(Request.QueryString("Name").Item);
Response.ContentType = "text/xml";
Response.Buffer = true;
//Response.Write("\r\nSelect a
directory\r\n\r\nCorporate Directory\r\n" + getBaseURL() +
"xmldirectoryinput.asp\r\n\r\n");
<% = outputString( dictionary.xmldirectoryMsgPagePrompt,
"dictionary.xmldirectoryMsgPagePrompt" ) %>
<% = outputString( dictionary.lblCorporateDirectory,"dictionary.lblCorporateDirectory"
<% = getBaseURL() %>xmldirectoryinput.asp
catch (err)
Response.Clear();
Response.Write(dictionary.msgGeneralError + " ( "+ name + " )");
Response.AppendToLog(name + ":" + err.number + ":" + err.description);
Response.Flush();
Not too sure where to edit the tag. I edited the tag that Corporate Directory was under but that did not do the trick.
