compact flash on cat-6504-E
Nov 6th, 2007
Hi guys,
I inserted my original compact Flash MEM-C6K-CPTFL256M on disk0 on SUP32-ge-3b. The goal is to backup the IOS on my flash.
I insert the flash:01:00:18: %FILESYS-SP-5-DEV: PCMCIA flash card inserted into disk0
but when i try to format or copy the output is:Router#format disk0:
Format operation may take a while. Continue? [confirm]
Format operation will destroy all data in "disk0:". Continue? [confirm]
%Error formatting disk0 (No such device)
Router#
and
Router#copy sup-bootdisk:s3223-ipbase_wan-mz.122-18.SXF11.bin disk0:
Destination filename [s3223-ipbase_wan-mz.122-18.SXF11.bin]?
%Error opening disk0:s3223-ipbase_wan-mz.122-18.SXF11.bin (No such device)
Which is the problem?
Thanks in advance for the support.
fcava Fri, 11/09/2007 - 06:13
I have two SUP but I'm trying with only one inserted so the active I'm sure it's the active.
It may be a problem with the size or the type of the flash card? (MEM-C6K-CPTFL256M)
