SDM with https cause a router to crash.
Nov 6th, 2007
Dear all.
My router is 2811.
I issue https to connect SDM.
There is no respone on my Internet Explorer.
The console message shows router crash and reboot immediatly after I issue https connection.
If I connect to SDM by using http.
Everything works very fine.
Could someone please tell me the solution to make https works as well as http.
thanks a lot.
PS. My IOS was upgraded to 2811NM with advanced IP service.
htarra Tue, 11/13/2007 - 11:22
There are some other very serious SDM bugs in that version. Your crash tracebacks aren't as important as the fact that the HTTP CP process has overflowed it's stack:
---- Partial decode of process block ----
Pid 3: Process "HTTP CP "
---- Current Process Stack (0x2EE0 bytes used, out of 0x2EE0 available)
CSCek55001 will crash the router when trying to access the router via SDM (If I remember correctly, this can have the exact same signature as your crash)CSCsg89879 will crash the router when trying to install SDM
