Integrate IPCCX with External Apps
Nov 6th, 2007
Hi:
Is there a way to integrate IPCCX with an external application?
Suppose I have an Application that generate N outbound calls. Can I put these calls into the IPCCX CSQ to be processed by an Agent?
smahbub Tue, 11/13/2007 - 11:28
There are also several features that enable customers to integrate various Cisco IP Communications products seamlessly into their Customer Interaction Network: "Cisco IP Communicator replaces Media Termination "Support for Customer Voice Portal (CVP) 3.0 (for all IPCC/ICM Enterprise and Hosted Edition deployments, except for the System IPCC Enterprise deployment) "Support for current versions of CallManagersee the Cisco IP Contact Center Enterprise Edition Software Compatibility Guide for a complete listing
http://www.cisco.com/univercd/cc/td/doc/product/icm/ipccente/ipctt_cg.pdf
Abdulbaseer Mohammed Tue, 11/13/2007 - 23:23
The answer is yes.
IPCC X users usually are looking for easy and smimple way out, if this is the case?
You can have your external app generate calls and conference that to a local DN or JTAPi port where you have an app pointing to IPCCx CSQ.
This is not recommended but quick and dirty way .
Baseer.
