ASA appliance sync's NTP OK, then indicates "no sync"
Nov 6th, 2007
I am at a Customer site today and am having a bizarre NTP issue occur.
The customers outside Perimeter Firewall gets his NTP time from the Border Router (which syncs to tick and tock).
I ran debug ntp events/debug ntp packets on the ASA, it gets a message indicating it synced just fine to the server.
When I do a "sho ntp status" on the ASA however, it shows unsyncronized...
This seems very bizarre... any input would be helpful.
Perhaps I am missing a command somewhere....
thx
htarra Tue, 11/13/2007 - 11:49
The bug id is CSCdx34174 which says - "NTP with authentication may
not work after reboot. Need to re-configure NTP authentication again as work-around.
So could you please make the remove this command from the configuration first and check?
If this action cannot bring improvement,please remove all the ntp configuration and reconfigure it.
If it cannot work yet,Please collect information using the following commands
show ntp status
show ntp assoc det
debug ntp packet
debug ntp validity
debug ntp sync
http://www.cisco.com/en/US/docs/ios/12_1/configfun/command/reference/frd3003.html#wp1020509
