Study Guides
Nov 6th, 2007
I just bought what I thought were the latest study guides from Amazon. Come to find out the guides are for the "old material" that expires today. What is the difference between the old and the new? Is it worth buying the new books?
erikjustinlee Tue, 11/06/2007 - 13:56
I would say that if you plan on suplementing those books with some current labs, and some other current material you should be ok. If you plan on just using those books to study your going to need to get the new ones. What I have been told is that they made some pretty big changes in thier primary objectives. Hope that helps.
Jim_Gargone Tue, 11/06/2007 - 14:02
Afraid that would be the case. Probably end up buying the new ones at some point but some stuff doesn't change I have the ACRC course on disk......
Thanx
