CATOS port disable dquestion...
Nov 6th, 2007
For the output of
show port 5/20
Port Security Violation Shutdown-Time Age-Time Max-Addr Trap IfIndex
5/20 disabled shutdown 0 0 1 enabled 122
Shouldn't set port enable 5/20 enable it?
And if that doesnt shouldnt
enable it? I run that command and it tells me the port is enabled, but I am still seeing it shutdown.
I have also tried disabling then enabling it, still shows shutdown.
Thx
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 11/06/2007 - 23:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The "shutdown" part of your output is not referring to the port status. It is referring to the action that will be taken if there is a violation of port security. Note that whether you have port security enabled or not it will still show this.
An example from one of your 6500 CatOS switches. You need to look at the first line of output and under the Status column. In this example it says "connected".
DC-BBP-F00-AS3> (enable) sh port 2/10
* = Configured MAC Address
Port Name Status Vlan Duplex Speed Type
2/10 RTPR02D connected 190 full 100 10/100/1000
Port AuxiliaryVlan AuxVlan-Status InlinePowered PowerAllocated
Admin Oper Detected mWatt mA @42V
2/10 none none - - - - -
2/10 disabled shutdown 0 0 1 disabled 222
Port Num-Addr Secure-Src-Addr Age-Left Last-Src-Addr Shutdown/Time-Left
2/10 0 - - - - -
Jon
uubozou11 Wed, 11/07/2007 - 08:18
Thank you very much, dont I feel like a fool. I was heading down the wrong road on this one, you cleared it up, thanks again Jon.
