BAT 6.0: Cannot add Remote Destnation Profiles
Nov 6th, 2007
Instantly receive "Record does not match the file format selected" error.
Insert RDPs in /common/bps/csvfiles/remotedestinationprofiles/insert/insert.txt
Failure Details :
Remote Destination Profile Name Error Code Error Description
5079RDP Record does not match the file format selected.
Result Summary :
INSERT for 0 RDPs passed.
INSERT for 1 RDPs failed.
Insert.txt
REMOTE DESTINATION PROFILE NAME,DESCRIPTION,USER ID,DESK PHONE MAC ADDRESS,PARTITION 1,DIRECTORY NUMBER 1
5079RDP,D-5079,5079,SEP00070E36A0FA,INTERNAL,5079
I have tried to export a manually created RDP into the file and then import it back, but I have received the same error.
Anybody has tried to do the same?
Thanks!
Tommer Catlin Sun, 12/02/2007 - 18:09
  • Green, 3000 points or more
Im getting the or similar error with import new users to cucm. Did you find a fix?
dfokin Mon, 12/03/2007 - 03:41
Hi all!
I have solved my problem.
When you add RDPs using BAT file with MAC Addresses, then you do not need to select RDP template. Using the template will generate the error.
