3750G-48TS-S uplink ports
Nov 6th, 2007
Are the uplink ports 1 gig or 10 gig.
If they are 10 gig, can I connect them to a 1 gig router interface?
rbaratta1 Tue, 11/06/2007 - 17:43
Thanks for the quick response. If I can impose on you further, I'm not sure in what configuration to use the 4 uplink ports.
I'm using 12 ports and they're all set to 1000. So I'm sure I need to use more than 1 uplink port.
Joseph W. Doherty Wed, 11/07/2007 - 04:32
You may not need more than one uplink port; much depends on how busy the other 12 are. Oversubscription on uplinks is common.
That noted, you also have the option to channel ports, usually up to 8.
If your uplink distance is within copper range, you can also use you "normal" copper ports for uplinks.
rbaratta1 Wed, 11/07/2007 - 13:03
Thanks much for the info. I didn't mention, as I should have, I'm pushing Video (FTP)over these ports. But you did cover this, and I'll
etherchannel these ports together.
