Unable to ping when applying crypto map statement
Nov 6th, 2007
I'm not able to ping my directly connected interface or any other ip addresses on my local subnet 201.196.33.24/29 when applying the crypto map statement to the interface.
is this the right behavior ? will this affect the tunnel negotiation/setup between the peers ?
thx
UACA-VPN#conf t
Enter configuration commands, one per line. End with CNTL/Z.
UACA-VPN(config)#interface fastEthernet 0/0
UACA-VPN(config-if)#crypto map ENLACE-UACA-BNCR
*Nov 6 23:43:10.991: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
UACA-VPN(config-if)#exit
UACA-VPN(config)#exit
*Nov 6 23:43:17.903: %SYS-5-CONFIG_I: Configured from console by console
UACA-VPN#ping 201.196.30.33
Sending 5, 100-byte ICMP Echos to 201.196.33.30, timeout is 2 seconds:
Success rate is 0 percent (0/5)
UACA-VPN#ping 201.196.33.25
Sending 5, 100-byte ICMP Echos to 201.196.33.25, timeout is 2 seconds:
UACA-VPN#conf t
UACA-VPN(config-if)#no crypto map ENALACE-UACA-BNCR
*Nov 6 23:44:18.427: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
UACA-VPN(config-if)#end
UACA-VPN#
*Nov 6 23:44:29.891: %SYS-5-CONFIG_I: Configured from console by console
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
UACA-VPN#ping 201.196.33.30
Sending 5, 100-byte ICMP Echos to 201.196.33.30 , timeout is 2 seconds:
UACA-VPN#
Overall Rating: 4.5 (3 ratings)
Richard Burts Wed, 11/07/2007 - 07:47
Glenn
I would say that was not the generally expected behavior. Without seeing the configuration it is hard to say exactly what the problem is. But my guess is that the crypto map is identifying traffic to the local subnet as traffic that should be protected by IPSec. But from the behavior it seems to not be what the locally connected devices are expecting. If you post the config details (especially the crypto map config and the access list used to identify traffic) we might be able to suggest a solution for you.
Rick
glenn.guzman Wed, 11/07/2007 - 09:25
Thanks a lot for your valuable input... Heres the running-config and also a brief comment on whats going on here...
172.4.4.0/24-->VPN3000----ISP----1841<--192.168.2.0/24
The VPN3000 will be the one triggering the VPN tunnel setup.
Remote host 172.4.4.5 will be querying a local database at 192.168.2.14:1000
According to my "remote peer" specifications I have to NAT the local address 192.168.2.14
to the Global address 172.17.0.65 in order for the VPN 3000 to accept returing packets.
As far as I know thats how they've implemented their ACLs in the VPN 3000.
Thats the reason for the static NAT entry in the running-config and thats also the reason for the
ACL 101.
Please let me know if this scenario is clear enough or if you need additional input from my side. Again, thx a bunch
UACA-VPN#show running-config
Building configuration...
Current configuration : 2550 bytes
version 12.4
service password-encryption
hostname UACA-VPN
boot-start-marker
boot-end-marker
enable secret 5 $1$n8of$osX1TuEuCWxuhMXwNp3WQ0
no aaa new-model
resource policy
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
!IKE Phase 1 parameters
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key 6 ***** address 200.122.146.39
!IPSec phase 2 parameters
crypto ipsec transform-set ENLACE-UACA-BNCR esp-3des esp-sha-hmac
crypto map ENLACE-UACA-BNCR 10 ipsec-isakmp
set peer 200.122.146.39
set peer 200.91.79.6
set transform-set ENLACE-UACA-BNCR
!traffic to encrypt according to ACL 101
match address 101
interface FastEthernet0/0
description WAN interface. Local peer for VPN tunnel setup
ip address 201.196.33.30 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description LAN interface
ip address 192.168.2.4 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Vlan1
no ip address
ip route 0.0.0.0 0.0.0.0 201.196.33.25
no ip http server
no ip http secure-server
ip nat inside source static 192.168.2.14 172.17.0.65
access-list 101 permit ip 172.4.4.0 0.0.0.255 172.17.0.64 0.0.0.7
access-list 101 permit tcp host 172.4.4.5 host 172.17.0.65 eq 1000
access-list 101 permit udp host 172.4.4.5 host 172.17.0.65 eq 1000
access-list 101 permit icmp any any echo
access-list 101 permit icmp any any echo-reply
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
password 7 08146D6D285413071C
login
scheduler allocate 20000 1000
end
Richard Burts Wed, 11/07/2007 - 10:00
Glenn
The original question is now easy to answer. As I suggested in my first response the access list that identifies traffic for IPSec includes your ping traffic:
so the router will take any ping request or any ping response and try to put it through the IPSec process. And that will prevent ping from working to the local subnet (and probably to anywhere else as well). Was there a reason to identify all ping traffic this way. It seems to me that since everything else in the access list is related to 172.4.4 that it would be reasonable to identify ping that way.
I am not sure that I understand the business about translating the address. And if you are going to translate one specific host then I am puzzled why the access list starts by identifying a whole subnet:
I also note that given this access list that the second and third statements are more specific matches for what will match in the first statement and therefore are redundant.
Rick
glenn.guzman Wed, 11/07/2007 - 10:17
Thanks for your reply it worked as soon as I removed those entries from the ACL.
Now the whole deal about the translation goes like this (I'll try to explain it the easiest way)
The NetAdmin for the VPN 3000 has configured the ACLs to ONLY permit TCP and UDP traffic with source address of 172.17.0.65. Thats why I have to statically NAT my local address of 192.168.2.14 to the global address of 172.17.0.65. I'm natting and then encrypting the nat'd traffic
Now, why am I configuring an ACL for a whole subnet ? Because the NetAdmin on the VPN 3000 specifically warned me about including that entry when configuring the ACL (according to his version we needed in order to allow some other traffic for testing porpoises)
I hope this whole thing is a little bit clearer to you now... let me know if you'd like additional info.
I'm about to start testing so I might be calling for help... ;)
thx again
Richard Burts Wed, 11/07/2007 - 10:27
Glenn
You know what the admin asked you to do, and if he asked for the subnet definition then that probably is what you should do. But since you are only translating a single address if they were to send you traffic for some address in that subnet I believe that you would discard it.
At this point probably the best thing to do is to test and see what works. If there are other issues let us know.
Rick
glenn.guzman Wed, 11/07/2007 - 10:32
I will and I'll let you guys know...
Thanks a bunch for your help Rick
Glenn
