ssl configuration on CSS11506
Answered Question
Nov 6th, 2007
For purpose of fixing upload file from IE6, I have been asked do configure something similar as a test server did:
SetEnvIf User-Agent ".*MSIE.*" nokeepalive ssl-unclean-shutdown
Since, my SSL configuration is too critical to do just for the test, can I get advice if the following I do will service the purpose?
ssl-proxy-list
ssl-server 20 unclean-shutdown
service ssl-slot3
keepalive type none ( witch already existed)
please confirm?
And also, please advice, if I need the specify the condition: (User-Agent ".*MSIE.*" )? if so, how do I do it?
Any comments will be appreciated
Thanks in advance
Correct Answer by Gilles Dufour about 9 years 2 months ago
the user-agent part is I believe just a filter so that you server only does the unclean shutdown for MSIE agent.
You can simply do the unclean shutdown for all agents, as only microsoft is a problem and the other ones do not care what you do.
Gilles.
Overall Rating: 5 (1 ratings)
Correct Answer
Gilles Dufour Tue, 11/13/2007 - 10:51
Gilles.
julxu Tue, 11/13/2007 - 20:28
Hi, Gilles
Thousands thanks for the confirmation. I will implement now.
