how to do a SRBS lookup?
Doc_ironport Wed, 11/07/2007 - 11:21
Just login to your IronPort box, go to the main Monitor page (the one you get when you first login), then down the bottom select "IP Address" in the "Search for" box and enter the IP address you want to find the reputation of.
Down the bottom of the resulting page it'll have a section "Current Information for X.X.X.X" and under that will be the reputation.
