Switching module problem
Nov 6th, 2007
guys i have just put NME-XD-48ES-2S-P in cisco 2851 i have put the latets version of IOS in it (c2800nm-adventerprisek9_sna-mz.124-11.T.bin) put still the router doesnt pick the module.......can someone tell me whats going on ....the router and the module are new from the box.......kindly see th error which i get while i was booting uip the router....can someone please help me as its bit urgent....thanks in advance
spremkumar Tue, 11/06/2007 - 22:49
  • Red, 2250 points or more
hi
As per the FAQ any ios feature set supports the module.
do refer the below link for more info...
http://www.cisco.com/en/US/products/ps5854/products_qanda_item0900aecd8028d16a.shtml
are you trying to install this card on a 3600 series router or in your 2851 router ?
also the error message which you have posted shows that you are trying to install some Port Adapter module and its not supported can u confirm whether you have recieved this error message from your 2851 chassis .
regds
lgijssel Tue, 11/06/2007 - 23:21
According to spremkumar it should work on any 12.4 and higher as this the migration path for 12.3(T). You have that already so I assumed it was needed to dig a little deeper.
Finally, I let the software advisor loose on this because the straightforward answer could not be found.
Please check the screenshot with the result in the attached document.
regards,
Leo
The_guroo_2 Wed, 11/07/2007 - 01:49
Kumar
This is the confusing thing its cisco 2851 and the mesage its giving is of 3600 i m going nuts :-)
