replace image of 3750
Nov 7th, 2007
I have the following Switch
WS-C3750G-24T-E with this image :
Can I replace the image with this image :
c3750-i5-mz.121-19.EA1d/c3750-i5-mz.121-19.EA1d.bin ?
spremkumar Wed, 11/07/2007 - 02:14
hi sanjay
i would suggest to compare both the ios images and find out whether you are getting anything out by degrading from 12.2 to 12.1
i did the same for both the images and found the following features are unique to 12.1 version code image when compared to a huge list of features available only in 12.2 version...
DHCP Client
RTP Header Compression
Standby Supervisor Port Usage
you can make use of the below link for the same
