NAC Issue
Nov 7th, 2007
hello guys;
I have nac 3310 with lite manager license,
there is no any switch managment menu on the CAM.
how can i handle snmp traps from swiches without this menu?
or is any other type of development?
thnx
pmccubbin Wed, 11/07/2007 - 04:25
  • Silver, 250 points or more
Hi Ehsan,
Please take another look in the CAM and let's be clear about the fact you are doing an Out-of-Band implementation of NAC.
Look for Switch Management-->Profiles.
You can use the default profile and add your first switch. You must then add a switch profile for each model of Cisco switch you manage.
Make sure that you configure the switch model, the SNMP port, and the SNMP read/write community strings to match the configuration on each switch.
Hope this helps.
Best,
Paul
pmccubbin Wed, 11/07/2007 - 06:21
Hi Ehsan,
Here's a dumb question which I should have asked you first: Have you added the license for a CAS?
You need to add the OOB CAS to your CAM and then you can manage a switch.
Hope this helps.
Best,
Paul
paqett001 Sun, 11/11/2007 - 21:04
Sounds like the same problem I had. I opened a TAC case and I was issued a new license. Both licenses need to be associated to the MAC address of the CAM. I had one associated to the CAS and one to the CAM. I understand it is a pretty common problem.
