using hsrp and routing protocol
Nov 7th, 2007
Hi all, can anyone tell me how the traffic will flow if I have 2 sites, they have 2 routers each, 1 primary and 1 backup, the active hsrp router routes via the e1. the backup uses the isdn, i would like to know how the routing protocol, eigrp would use the isdn on the other router if the e1 went down, would the pri router learn routes from the backup router to go via that link id the primary is down ?
greg.day Wed, 11/07/2007 - 08:24
Are you using HSRP tracking on your e1 interface on both ends of the link? Is the link point-to-point, frame, MPLS? That could determine whether or not both ends of the link appear down. If they both register as down during a failure, then HSRP tracking will swing the virtual address over to the secondary router on both ends. If not, eigrp will use your internal interface (or direct connection between your routers) to pass the traffic to the secondary router. I'd recommend tracking as it will maintain a consistent optimal path for your traffic on both ends.
